predator tuneing
Old 08-07-2003, 11:16 PM
ben8520's Avatar
Default predator tuneing
I am running 31.4 WOT spark and 925 WOT o2 sensors is this good or should i add more or less spark or fuel. what are the stock readings am i making more power then stock
Old 08-08-2003, 01:24 AM
Restricted User
CAT3's Avatar
Default Re: predator tuneing
Are you getting any KR? if so, reduce the spark. O2's look a little high but if you can wideband thats the safest and best way to tell what your A/F is. I was running 34.4* @ WOT and 905 on the O2s, no KR, but we ended up reducing the spark so if it see's detontation it wont fry. Not sure what the factory tune is for WOT as for A/F, but you will make most power at about 13.1:1, so you could go a little leaner maybe.
Old 08-10-2003, 08:27 PM
soundengineer's Avatar
I thought most power was 12.6:1
Old 08-17-2003, 09:16 AM
Michael Ozorowsky's Avatar
I made most power at 12.8:1. It's a little rich, but I'm gonna experiment some more soon.
Old 08-18-2003, 12:37 PM
Restricted User
CAT3's Avatar
ON a dyno yes, as theres less load, and on street should be around 13:1 give or take a .1
Old 08-18-2003, 10:19 PM
WS6FirebirdTA00's Avatar
from what im told, 30* of spark and 900mV for the o2 numbers. just listen for any detonation at high rpm
Old 08-19-2003, 11:09 AM
Kansas 99z28's Avatar
What exactly does detonation sound like??
