Rotating Crank Pulley Question...
Well I got the engine out of my car but had left the my 6 speed tranny in neutral instead of putting it in a gear. Now my crank spins freely on itself. Is there a way to get the crank pulley off now and keep it from spinning freely on itself so I can get the bolt off? I don't have an air gun either...
thanks
thanks
I just made the same mistake a couple weeks ago. With my engine on a stand, I threaded a bolt into the crank where the flywheel bolts up and cranked it against the arms of the engine stand. I used a bolt soft enough not to hurt the crank, but sturdy enough to not break. It work very well and didn't hurt the crank at all. Don't use a bolt your going to need later, it will bend the hell out of it.
There are tools that you insert into the pulley/balancer to hold it in place why you break free the balancer bolt. A flywheel tool will also work. Get a extra set of hands to help
Summitracing sells one. #SME-906008
I had used a another brand one once and it did work. suggest using 3' - 4' cheater bars to help.
