Head Questions
Head Questions
I have a 231/237 .598 .596 cam in my 98 with stock heads. Curious as to what I could swap as far as heads on a budget without having to worry about ptv clearance. Thanks for your help.
I have almost the same cam in the same year car, I think as long as you keep the same ratio rockers and pushrods and make sure the valve stems are not longer and you should be fine. Also a stock gasket.
It would all depend on the chamber size you want and if you want the heads decked. LS6 heads I think would work. I'd call which ever company you want to use head wise and run this by them.
