12 bolt, and suspension to go along
Hey guys, i was just wondering what new suspension peices i would need If i put in a moser or a strange 12 bolt rear. Can i use stock torque arm or LCA's? I jut wanto get a feel for how much it would be to swap.
If your going with the 12 bolt my suggestion would be to upgrade your Torque Arm, LCA's preferably adjusatble, and do an adjustable PHB. It will save you some headaches and improves your handling greatly.
if you NEED to get your car on the road then yes you would be fine using stock stuff but if you just put a strong rear on that can handle traction you might as well use it. besides stock torque arms are notoriously weak and can leave you stranded
