Hotcam+bolton car result #2
Old 05-20-2008, 09:28 PM
Striped02WS6's Avatar
Default Hotcam+bolton car result #2
hey everyone ...this was my 2nd time at the track with the mods i have (results and mods can be found here https://ls1tech.com/forums/drag-racing-results/920243-hotcam-only-car-check-out.html )....car ran great tonight i made a few changes to my combo by switching out the factory hurst for a pro 5.0 (made a huge difference) and taking the plunge and hooking up some 255 M/T et street radials.
i went relatively easy on the car because i have a stock 10 bolt rear but i was able to pull a best of 2.04 60ft (i know i know) and run 12.70 at 113 MPH.....there is obviously more left in it....the car is getting a set of ported 241 heads and a 9'' rear with 4.10s
comments..what does everone think it will do with the next wave of mods comming in?
thanks for looking and commenting
Old 05-20-2008, 09:44 PM
BLK85's Avatar
I think there is something wrong with my car. I have the 12 bolt and 4.11 gears. I just drop the skirt and start trying a little harder. I could only manage a 12.65 at 110, but my 60 was better, 1.86.
Old 05-21-2008, 08:47 AM
i wouldnt say there is something wrong with it...there just 2 different cars..maybe it in the tune man..i got a great street tune from caspernicus on this site...pm me if you are interested in getting in contact with him...very affordable....i was trapping in the 110s when i was having alot of tire slip in second gear....are you slipping at all from the 1-2 shift?
Old 05-21-2008, 08:39 PM
ads_99ta's Avatar
well you got your 12s but i'm sure you're not satisfied either. i think you could have pulled 12.40s if you wanted to push that 10 bolt anymore. can't wait to see what you run when your car is finished.
Old 05-21-2008, 09:03 PM
BLK85's Avatar
Nope. As far as the tune, Im probably going to be buying HP tuners soon.
Old 05-22-2008, 10:27 AM
PewterScreaminMach's Avatar
Nice. Get that 60' down and it's a 12.3-12.4 car with a broken 10-bolt. With those new mods, no reason you shouldn't be hitting bottom 12s compared to this setup.
