Does anyone have pics or info on the gmpp acc drive yet?
My 19155067 came in the other week. A/C mounts lower pass, alt is upper drive, P/S reservoir is to left of alt and the P/S pump is lower left of the alt.
Heads up for anyone looking at this and wanting to run braided power steering lines, the pulley comes too far back and hits the fitting. I've just ordered a Unisteer banjo fitting to clear everything.
Heres a poor pic of it semi installed - I took the ps pump and res off until I get the banjo fitting but its drawn in the photo. The A/C comp is also not installed because it doesn't clear my frame and I don't have the rest of the system yet so I'll deal with that later. I don't know much about the other accessory drives but I attached a pic of the a/c bracket, looks like all 4 rib compressors would have to go below the water pump anyways.
Theres also a pic of the alternator with 3 terminals and the p/s pump
