????stagger setup????
Old 05-21-2008, 02:47 PM
gopherit98's Avatar
Question ????stagger setup????
im about to get some eighteens on my car all the way around as of now i have 18/19 i have 40 series on the front and 30 series on the back with 18's the tire stagger size is always 40/35 wouldn't this make the rear tires look smaller? than the front with the rim being the same size my car is stock height.... any ideas or should i go 40/40 series tires all the way around if anyone has pics of a car stock height with a 40/35 setup or 40/40 please post pics or give me a suggestion i don't want to look like im riding on spare tires because the new rims are black...........
thanks
scott
F0R SALE: Brand new Zex ls1/lt1 efi wet nitrous box 150 plus shipping 50 for brand new Grant steering wheel Black/red 200 for both free shipping both brand new! Pm me for details
Old 05-21-2008, 02:58 PM
Mattism78's Avatar
You might want to do some research on why tires have the numbers on them. You can have a 35 series tire that is taller than a 40 series tire because of the width. The first number on the sidewall is the width, the second is the size of the sidewall, (aspect ratio) it goes by a percentage of the width, the last number is your wheel size.
So if you're running a 255/40/X up front and a 315/35/x out back chances are the rear tire will be taller. Keep in mind some manufacturers run a bit smaller on sizes while others run bigger. The numbers SHOULD be right. Should.
edit - Also staggered size doesn't always refer to the wheel height, it often refers to the wheel width.
Old 05-21-2008, 04:38 PM
99Bluz28's Avatar
What are your tire/wheel sizes?
Old 05-24-2008, 08:22 PM
gopherit98's Avatar
my tire and wheel sizes are 245 40 18 .............. 275 30 19
