LS vs LT rear brakes
Old 05-22-2008, 04:37 PM
toplessHO's Avatar
Default LS vs LT rear brakes
Just picked up a set of LS rear brakes
was told it was everything and Im missing the brackets
and the drum brake assemblys for em brake.
I did get the em brake cables and the hard lines and flex hoses.
I also have an LT rear that I would like to adapt the brakes to but it has everything different.
Does anyone have any pictures of the parts laid out so I can see whats missing.Both the LS and LT rear housings are interchangeable correct?
The rear end I have is a 97 and the brakes are a 98.
Old 05-22-2008, 05:00 PM
phantomzer0's Avatar
The difference between the two is barely noticeable. I honestly wouldn't bother with them. Your going to get into a lot more money that you want to. If you do the fronts that should be plenty.
Old 05-22-2008, 05:34 PM
toplessHO's Avatar
not sure I know what you mean
just looked at the parts illustration and nothing is same between systems.
I did find out Im missing caliper brackets,dust shields,em brake shoes. I have the caliper brackets for the LT rear but not the same.
Old 05-22-2008, 06:06 PM
ROCNDAV's Avatar
I've posted these many times in different threads, but never all together.
Here are the 93-97 (LT) rears:
Here are the 98-02 rear (LS)
Here's the 98-02 Ebrake system:
