Primary and Secondary VE
Old 05-25-2008, 04:07 PM
rangerjim's Avatar
Default Primary and Secondary VE
I don't understand the existence of 2 VE tables. I have read that both should generally match but why have 2?
Any comments would be great.
Old 05-25-2008, 04:16 PM
LS1TECH Sponsor
foff667's Avatar
Primary-used when the maf is still active but only as a sanity check for the most part up to 4000 rpms and then maf takes over
Secondary-used when the maf fails but has less resolution than the primary
Why did GM use two? Who knows, redundancy at its finest.
Obviously they realized there was a flaw in that thinking and in 01 simply had the primary do the work in both maf & SD mode.
