will 97 engine harness plug into 93 harness
looking to take my motor out of my wrecked camaro and put it in my 93.. is it the same harness or what do i have to do to make it work
Might be better if asked in the LT1 section, But to answer your question the harness is different and you will need to use the 97 harness UNLESS you remove the items that came on a 97 but not on a 93. better off swapping the computer and harness off the 97 to the 93 very easy to do and will save alot of problems.
