Gaskets/Bolts Needed For Cam Swap
Ok, this should be an easy search because I've seen this exact topic before I just cant find one through search
anyways, for my cam swap/overhaul I have these:
cam
springs
pushrods
ls6 ported pump
ls2 chain
Now I need these:
Headbolts
Head Gaskets (cause i'm porting ls6 heads also right now so do I order ls6 head gaskets or ls1? or are they the same)
Crank Bolt
I'm also putting on headers so just header gaskets right? or do I need header bolts too (are they one time use?)
Now does anyone have part numbers for these? Is there anything else I need like do I need a timing cover or anything like that? (NOTE My car is a 98)
THANKS for any help
cam
springs
pushrods
ls6 ported pump
ls2 chain
Now I need these:
Headbolts
Crank Bolt
THANKS for any help
LS1Tech Premium Sponsor
We've got everything you need including the bolts and gaskets for your swap, and competitive prices too! Let me know if I can help, and we'll be glad to put together a quote with all the parts you need to do the job right
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
