Do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8??
Old 05-27-2008, 03:07 PM
LSxChevelle's Avatar
Default Help!! Do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8??
Like title stated...do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8?? I just pulled all pistons since the have the little dimple which would usually indicate which way the piston goes in. The dot goes towards the front of the motor. Well in that case if I put the pistons back in the rod bearing tangs on 2,4,6,8 would be on the opposite side of the centerline while 1,3,5,7 wouldn't...
Putting new pistons/rods in so should the tangs face outside on both sides of the motor??
Old 05-27-2008, 03:59 PM
Anybody??
Old 05-27-2008, 05:06 PM
vaughn4's Avatar
bump.. also need this info.
Old 05-27-2008, 09:18 PM
KCS
Moderator
KCS's Avatar
The tangs face outwards, closest to the panrails, on both sides.
Old 05-27-2008, 10:44 PM
vaughn4's Avatar
even when using stock rods? anyone?
Old 05-28-2008, 11:41 AM
The dimples on the stock piston should face forward, right? If that is true, the LS6 and 5.3 I pulled apart would have the tangs inward (away rom panrail) on 2,4,6,&8.
Old 05-28-2008, 11:44 AM
https://ls1tech.com/forums/showthrea...ighlight=tangs
In this thread I found this comment...
Originally Posted by -Joseph-
On aftermarket rods the bearing tangs need to face away from the cam or engine centerline. On the stock rods half were one way and the other half opposite (all pistons installed the same, #1 piston can be used in #2 hole, etc.). With aftermarket rods half the pistons will end up reversed compared to stock, odd # will be one way, and even # cylinders will be opposite. There is also an upper and lower rod bearing, the upper is the one on the rod itself, lower is rod cap.
When its all said and done, none of the chamfered edges will be together, the chamfers on lets say #1 and #2. #1 will be facing the front of the engine, while #2 will be facing the rear on the same crankpin.
Old 05-28-2008, 12:39 PM
vaughn4's Avatar
you are correct. since i work for gm i went upstairs and found the 98 camaro service manual. here is a direct quote, "position the connecting rod so that the flat area on the bolt flange faces the front of the engine block." so odd numbers will face one direction and evens will face the other.
Old 05-28-2008, 12:40 PM
Russ K's Avatar
This is how the connecting rods face in a LSx engine. They all face the same direction.
Russ Kemp
Attached Thumbnails Do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8??-clipboard01.jpg
Old 05-28-2008, 12:48 PM
vaughn4's Avatar
perfect.
Old 05-28-2008, 12:51 PM
Very interesting how you run them the same in stock applications and and opposite for aftermarket rods...
Old 05-28-2008, 01:18 PM
vaughn4's Avatar
maybe this plays a factor in people spinning number 1 rod bearing in a stock configuration. ?
Quick Reply: Do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8??
