Some Research for New motor (Guru's inside Please)
I've got 103,000 miles on my current shortblock...nothing leads me to think it's going anytime soon, so I can build up another at my leisure.
I had a few questions though.
1. I want to keep the bore small so I don't have to spend more $$ to have my MTI heads reworked for the large bore, but I'd like to get a lil more CID. I was thinking of going with a slight overbore (Please insert your opinion of a good overbore that will take advantage of Stage 2 MTI heads), with maybe an offset ground crank and forged rods.
What kinda CID will I get with that kind of set up (I know that there is a lot that can change but a round-a-bout number...355...367??
2nd Have the offset ground cranks been able to hold up to 450 N/A HP with a healthy shot of gas on top..that is what I'm shooting for..as of currently I'm in the 420ish rwhp range w/my MTI H/C set up and don't expect I'll go down in rwhp when I do the build up.
Anyone have a clue as to what that kind of shortblock will cost? Block, crank, forged rods, pistons....I can price the pump, timing set, etc...but someone that has done a build up of a 346 or better what have your prices been? I appreciate the time guys!!
Later...
Later...
Re: Some Research for New motor (Guru's inside Please)
...offset ground cranks do not yield a significant increase in displacement...
therefore, consider a clean up hone on your block and a stroker crank, rods, and new pistons...
hrm. overbores really do help to unshroud the valve if you have 2.05 or larger valves. If you have 2.05" valves, the cost for a combustion chamber rework may not be all that bad. I'd think about it.
You cant do a medium overbore on one of these aluminum blocks without going ot an iron block, which in my opinion isnt a great option unless you are going with big stroke. A big stroke and mild overbore is probably more expensive than a 4.125" re-sleeve setup with stock rods and crank (like my 387).
None of these options are cheap, but....
Super Moderator
I went with a new 6.0L block. They have a standard 4.001 bore which yields 364cid with a stock crank. The bore is .090 larger than stock LS1, so no major reworking of your heads is needed. You could have the valves unshrouded a little for better flow.
