what are SVO 30lb injectors compaired to FAST 33lb Fuel Injectors ?
what is the difference between SVO 30 Lb Fuel injectors Compaired to Fast 33lb Fuel injectors ? Cause i've been hearing that alot of people have been running these SVO's 30lb injectors for a little time in there 402 + cid engines ? is this good or not ? what would the DUty Cycle be for the FAST 33lb Fuel injectors i know they will be almost maxed out , but will they work ?
Are you referring to the FAST 33lb injectors or the SVO 30lber ? Was that 460rwhp/405rwtq ? You said that they were running at 80% is this at WOT ? So i should be fine to run these 33lber a little while , i've just been letting people put a bug in my ear about these are too small .. so idk i was just wonder
