ls1edit custom tune locked, turner moved away
Hello, Is There A Way To Unlock The Tune From Ls1edit. Would Efilive Work? Any Help On This Or Pull Ecm And Put A Small Cam , I Have Stage 2 Heads 10.96 Compression And 228/228 .588/.588 114+2. 114 Lobe Separation 112 Intake Center Cumtom Grind Cc-3724r/3724r Valve Timing @.050 Int 2deg Openbtdc Exh Open 50 Bbdc Close 46deg Abdc And -2 Atdc
