How do you size an intercooler?
Old 05-31-2008, 09:38 AM
Rhythm's Avatar
Default How do you size an intercooler?
I'm looking to get an intercooler and I was wondering how to size one up... Do you go by turbo compressor flow rate only? This will be for a rear mounted TC78.
Thanks!
Old 05-31-2008, 10:00 AM
SPRAYED 01's Avatar
With a good quality air to air i would say bigger is better.
Old 05-31-2008, 10:11 AM
deadmanTA's Avatar
The biggest one you have room for.
Old 05-31-2008, 10:13 AM
camarols1's Avatar
Fit the biggest possible intercooler you can in the space that you have.
That way when you turn up the wick later, you will not have to redesign the setup.
Determine your HP goals, then check out how much space you have to work with.
You can make up a box from cardboard in the dimensions of an intercooler that you THINK will fit before purchasing anything.
This will help you get an idea where the inlet/outlet need to be.
Calling a sponsor with your goals would be helpful too.
With all the FI builds on this site, you can do a little searching to see if someone has a similar car as yours and see what they did.
Quick Reply: How do you size an intercooler?
