Power steering Reservoir
Old 05-31-2008, 10:21 PM
TRlGGER's Avatar
Default Power steering Reservoir
I found a while ago that it is leaking from somewhere so i cleaned it real good. Now i have found that it is leaking from the actual power steering reservoir cap. Is this a common problem? or should i get a new cap?
Old 05-31-2008, 10:28 PM
vjo90rs8's Avatar
I've noticed the same thing. The top of the reservoir/around the cap always looks wet. Always thought thats just how it is, but maybe not. Would like to know if I need a new cap also.
Old 05-31-2008, 10:52 PM
TRlGGER's Avatar
Maybe some sort of O-ring in the cap or some type of sealant. I dont know but id like to fix it.
Old 05-31-2008, 10:55 PM
vjo90rs8's Avatar
I did a quick search and it seems to be pretty common.
Old 06-01-2008, 02:28 AM
2000Hawk's Avatar
Happens to mine also, first time i noticed i thought the Power Steering was taking a sh*t. When i took off the cap the entire bottom area thats covered by the cap had fluid sitting on it. Im not sure if the seal in the cap gets worn out or what, but it seems to happen to alot of them.
-Joel
Old 06-01-2008, 02:31 AM
LT1-DAN's Avatar
My LT1 does it too.
Old 06-01-2008, 11:28 AM
disavowed10's Avatar
Default ps leak
my 99 z28 was leaking out the top too. turns out that someone filled it to the top and i guess the pressure was probably forcing it out? i took some of it out with a straw and sure enough.. no more leaks.. now its jus leaking from the rack and pinion boot which i heard isn't supposed to have power steering fluid..
Old 06-01-2008, 07:48 PM
TRlGGER's Avatar
Now that i know its a common thing and not really a major problem i feel better. Its a load off my back. thanks guys!!!
-Joel
Hey your the guy with the cam and the straight pipes that i met at the last meet, arent you?....if not whoops..sorry.
if so...seeya at the next one!
Old 06-01-2008, 08:50 PM
94'BLKBRD's Avatar
does your pump whine?
Old 06-01-2008, 08:57 PM
TRlGGER's Avatar
not that ive noticed. Does yours?
Old 06-01-2008, 10:20 PM
2000Hawk's Avatar
Your correct that was me, i should be at the next one if i change my water pump by then.
-Joel
Old 06-01-2008, 10:27 PM
TRlGGER's Avatar
-Joel
need a hand?
Old 06-02-2008, 01:33 PM
BubaGumpShrimp's Avatar
mine leaks at the cap as well, guess its a common thing..
Old 06-03-2008, 01:29 AM
94'BLKBRD's Avatar
If your pump is whining then you're going to need a new one. If it's just leaking from the cap just replace the o-ring/seal on the cap and see what happens.
