bmr lca bracket help pics, problem
im currently in the middle of installing ya'lls weld in relocation brackets. as the car sits know, the springs, shocks, sway bar, and stock lcas are removed, basically bare axle wirh the panhard bar and jack holding it up. can we just weld these brackets under this current setup, or do i have to put all the new suspension componets in then weld them up. also i need pics of the bracket welded on so i can see where the welds are and what angle where the bracket is at.
thank you
thank you
