popping sound after installing new sway bars, endlinks the problem?
Well my cousin and I spent today working on my car. We replaced a solo bleeder which had been crushed, put a new boot on a caliper pistol, bleed the brakes, installed a new A/C tensioner, changed my oil, installed a new door handle bezel, and put in my new BMR sway bars. The sway bars came with energy suspension endlinks and bushings. One of the endlink bolts was bent, so I went to autozone and bought a new set of endlinks. But after getting out on the road, they are popping like crazy. We jacked up the rear when installing the rear endlinks and had the A arms in the front on jack stands when we installed the front endlinks. I do not think the problem is the sway bar bushings, just the endlinks. But I am trying to figure out what is wrong, or if the endlinks bushings just need time to break in???
Thanks
Thanks
Thanks
I did my install on ramps, but you should be fine with the arms on jackstands. You'll be fine going to school... Ive driven my car short distances in worse condition. I'm not sure thats exactly whats making the noise, but I would check all the easy stuff first (like tightening the endlinks).
Thanks a bunch,
Robert
