piston location at tdc
ok, so i had a ptv issue with my etp heads milled .040, et said i may have set up the cam wrong, i went dot to dot, at dot to dot the piston should be flat and even with the block or about a quarter inch in, , my cam is a 231/235,615/621, 111+4, i need help, thanks, by the way the exhaust valve is what hits.
