HP gains from 90mm intake/TB?
I am thinking of getting a 90mm Intake and TB and wondering if the HP gains will be worth the money? Anyone have any numbers from adding this combo?
It was not a ported 92 intake or 92 T/B, just stock. I haven't heard of loss of tq either but in the last year or so, i've learned real world numberss don't necessarily jive with info I find on here. In case some are wondering, I have stock heads but I also have long tubes, .585 lift cam, and all suspension upgrades, K&N FIPK, basically all other bolt ons so i'm at a loss myself.
If your just a bolt-on car or a cam only car then you will be better off with the LS6 for now. Some people even with heads and cam still prefer the LS6 as well over the Fast set-ups. When it comes down to that time i will have to see whether i can justify spending $1500 for an intake. But an LS6 is always good, especially over the LS1 intake.
-Joel
-Joel
LOL it's not just about gaining HP. You have more room up top to pull your motor to and actually have it make power.
I ran an LS6 on my cam only setup for a long time, and now I am getting ready to throw a 90 on so I can spin my motor higher. My LS6 seems to run out of lungs at 6700 and the powerband peaks off.
where are you guys overpaying for your intakes??
TSP is still selling the intake for $1100 with the TB included....granted its not ported.
subtract the $300+ for selling your ls6 if you have it...and you're well below a grand for 15-20hp.
i'm looking to do it to my cam only car....jsut because i don't have the $$ or the mechanical means to do a head swap right now.
I didn't tighten mine down enough, and after going over them over & over, I sealed up a leak, and it gained a shitload.
