$$ Misfire Who Will Figure It Out??? $$$
ok winner gets ten dollars via paypal
2000 t/a
let it idle today and it started misfiring, check engine light was flashing
pulled each injector plug off and every cylinder would die more than it was already missing.
each wire is sparking and they are brand new tightened and pushed down all the way.
fuel pressure is at steady 55 pounds
each coil has spark as well
when i drove it after i happened it revved really slow and it was an obvious misfire. when on the road i would hold the pedal half throttle it would jerk to no power to go.
ten dollars for your solution that gets it
and plugs are also like 4 months old
2000 t/a
If you can, take the car to autozone or advance auto, they will scan the code for you. Find out whether it is just a random misfire or a particular cylinder.
Make sure you don't have a plugged exhaust (cat clogged?)
If the valves aren't opening/closing right you can have a misfire from that (ask me how I know...) Any strange valvetrain noises?
Don't want the $10, just trying to help
I'm gonna go with cracked plug porcelin. I had a missfire under load and it turned out number 7 had 4-5 cracks in it. And what kinda plugs? I had poopy champions that caused more problems then they fixed.
1 Post
this is my #4 spark plug after it was replaced 1 month ago. i had cylinder #4 misfire, but it took the computer forever to find out it was cylinder #4
i would say check ur spark plugs one more time man! i was in the same boat as u buddy
yes i would say cracked spark plug if you have ngk's but you might not see anything wrong with the plug on the outside just replace the plug for the cylinder with the most miss fires it will only cost maybe two bucks for the plug then you can rule that out if it does not work.
LS1TECH & Trucks Sponsor
1) bent pushrod
2) broke spring
3) O2 sensor
4) dirty MAF
2) broke spring
3) O2 sensor
4) dirty MAF
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
