Coolent Light Came On
Old 06-03-2008, 08:23 PM
my bandit's Avatar
Default Coolent Light Came On
my add coolent light came on so i added more coolent in. it is now at the full level (one for engine hot) when the engine is cold. should i worry about the light being on or should i just leave it alone?
Old 06-03-2008, 08:32 PM
Johawk's Avatar
The sensor went bad... this happened on my 99 Formula... just pull out the light bulb lol
or replace the sensor on the radiator end tank next to your battery. its held in with a clip and O-ring to seal it. If youre fast enough you wont lose too much coolant
Old 06-03-2008, 08:34 PM
my bandit's Avatar
how much should the sensor cost?
Old 06-03-2008, 08:38 PM
Johawk's Avatar
I think it cost me about $30. I got it thru my cousin who works at a stealership so I might have got a slight discount... He told me they go bad all the time and that alot of GM cars have the same part number for that sensor.
Old 06-03-2008, 11:25 PM
Blazingz28's Avatar
I just unplugged the sensor its on the driver side of radiator i believe, just make sure to check it every now and then.
Old 06-03-2008, 11:38 PM
LT1-DAN's Avatar
If you think that you might forget to check the coolant level on your own, I would just get a new sensor and not just leave it unplugged. Better to be safe than sorry.
Old 06-04-2008, 02:24 AM
needadvice's Avatar
http://www.rockauto.com/catalog/x,ca...,parttype,2184
could be cheaper at Advance Auto???????
Old 06-04-2008, 02:27 AM
ae13291's Avatar
my light came on once when i had full coolent and then it shut off on its own, i guess the sensor gets all clogged and messed up from the dex cool crap, im runnin the green on mine now tho
Old 06-04-2008, 08:25 AM
my bandit's Avatar
it only comes on when the car is up to temp.
i just used the dexcool b/c thats what it said to use
Old 06-04-2008, 01:03 PM
ae13291's Avatar
wow thats weird, well mine came on when i just started the car, then i turned the car off and checked the coolent, it looked good so i started the car and drove off, after about 2 hours the light went away by itsself! it could be the sensor has residue over it or is dirty, u can try cleaning it first
