Wheel adapters
Old 06-04-2008, 04:05 PM
maxgee's Avatar
Default Wheel adapters
There aren't a lot of options for wheels for fbodies, unless you go with a custom three piece wheel which runs about 3k for a set of four wheels. I would rather take a ski trip then put that much money in wheels. I did find a company in California that make wheel adapters and wanted your opinions. I won't road race or drag with them, but this opens up the field of wheel choices. They run about $65 per adapter.
http://www.wheeladapter.com/bolt_pattern_changes.asp
Old 06-05-2008, 10:56 AM
maxgee's Avatar
Asking again...anyone?
Old 06-05-2008, 10:59 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
what do these run?
Old 06-05-2008, 11:42 AM
maxgee's Avatar
Originally Posted by Z28/2002
what do these run?
$65 per adapter
Old 06-05-2008, 03:41 PM
Z28/2002's Avatar
You'll still need a custom offset with the spacers
Old 06-05-2008, 05:02 PM
Xsta Z 28's Avatar
A qualtiy adpter with quality lug studs is about as strong factory mounting, I have no quams running adapters.
Spacers, I would recommended longer and stronger lug studs.
A wheel and hub centric unit is even better.
