What size injectors for procharger?
Old 06-05-2008, 11:03 AM
M-Ten's Avatar
Default What size injectors for procharger?
What is the recommended size when running a procharger? I plan on running only about 8lbs. of boost to start off with. I have a guy selling his D1-SC and it comes with #42 injectors.. Will that be big enough?
Old 06-05-2008, 01:28 PM
M-Ten's Avatar
can anybody tell me? Will 42# injectors be enough to run 8lbs? Just as a temporary thing?
Old 06-05-2008, 02:08 PM
WHPLASH's Avatar
Those will work fine, but I would get 60lb'ers and be done with it. You have room to grow as I know you will. Everyone on this board can testify to that.
Old 06-05-2008, 02:16 PM
bigblock4-speed's Avatar
running 60pound injec. - they work well, and its just a 8psi car.. street driven.- D1SC
Old 06-05-2008, 02:41 PM
M-Ten's Avatar
What is the duty cycle like on #8's with #60 injectors?
Old 06-05-2008, 02:50 PM
DanWS6's Avatar
I went with 60's. IT's funny, you tell yourself 8 pounds of boost will be enough.
And it is.
for a while.
Then you want more.
Old 06-05-2008, 02:53 PM
M-Ten's Avatar
Oh I know I want more, but the reason I'm asking is because the guy selling it has #42 injectors that are coming with it.. If they won't work on #8's then I will try to get a lower price without them.
Old 06-05-2008, 04:11 PM
allthrotle's Avatar
They'll work for 8lbs but, Im sure the 42lb'ers are going to be working their *** off. I bought 60lb'ers. and plan on running 8lbs.
Old 06-05-2008, 04:52 PM
BLNLS1/RX7's Avatar
You need to go with seimens 60lb. to be safe.
Old 06-05-2008, 05:17 PM
M-Ten's Avatar
Yeah that's what I was thinking... What are you guys' duty cycle on #8's with #60 injectors?
Old 06-05-2008, 05:23 PM
BIG BAD BLACKSS's Avatar
I agree, get some 60's. You can pick a new set up for just over $400
Old 06-05-2008, 05:40 PM
blownws6_nc's Avatar
yeah, get the 60's for sure, I've got 42's running @ 101%, so I need some as well if I dont sell the car.......
Old 06-05-2008, 07:47 PM
M-Ten's Avatar
Haha, guess I will then.. thanks guys!
Old 06-05-2008, 08:24 PM
dcvingv6's Avatar
+432423 on the 60's, thats what i am running.
Thanks...
--Mike
Old 06-09-2008, 02:44 PM
autosay97's Avatar
If its a stock motor the 42's are fine for 8 psi.
Quick Reply: What size injectors for procharger?
