Need help soon
Need help soon
OK i have been having a lot of trouble since i have put my tranny back in.....
Sputtering really bad at wot, random dieing...and acting like a vacum leak....At idle the rpms jump all over the place 1500 and below .when i first turn on the car it idles at like 1100 or higher some times...
What i have done before this started is put my tranny back in remove the ac and smog, air ,and all that stuff change the oil and plugs and wires and remove my zex kit....Fuel pump is grannatelli 255 got it two months ago ..
No cats true duels long tube headers ...Mods in my sig
I have changed the o2 sensors regulater fuel filters checked fuses.......
codes are
p0418
p0412
p0405
p0154
p0134
p0132
p0131
someone please call me at 806-330-1075 if you have any ideas i need help
codes are
p0418
p0412
p0405
p0154
p0134
p0132
p0131
p0418
p0412
p0405
Are all from the emissions, they would need to be edited off.
p0154
p0134
p0132
p0131
Are all o2 sensor related, break out a scanner and check the values. Check the wiring as well. I think that the rear o2 sensors have to be edited off as well.
Get a multimeter.
Get some carb cleaner or whatever and spray for vacuum leaks, just don't set anything on fire.
p0412
p0405
p0154
p0134
p0132
p0131
Get a multimeter.
