Changing Springs
Old 06-06-2008, 09:36 AM
1BadTA13's Avatar
Default Changing Springs
i know ill probably catch hell for asking this but my pro-kit is coming today and i was wandering if there was a step by step guide on here somewhere on how to do it. from what i hear its easy but ive never worked with suspension before. Search was worthless.
Old 06-06-2008, 09:50 AM
02texasz28's Avatar
https://ls1tech.com/forums/suspension-brakes/422236-lowering-guide-newbies.html
Scroll all the way down and there will be an install guide for the front and rear just click on the link.
Old 06-06-2008, 12:45 PM
z28bryan's Avatar
www.ls1howto.com
Notes:
-I don't think most people have needed a pickle fork to separate the spindle... I just used a hammer
-Lots of people's top shock nut is seized and requires cutting. Some people cut the decarbon shock shaft
-Slide the master cylinder completely off of the bolts and aside. I didn't and tried to get the torx bit in there and long story short I had to cut the torx bolt off.... no fun
-Consider removing the coilover assembly and having a shop do the spring compressing and putting the new spring over the new shock if needed. Spring compressors are a pain in the butt in my opinion.
-For the rear spring swap, don't forget to unbolt the swaybar endlinks
