Wet kit timing?
Get a timing tuner or a nitrous tune. I took the latter of the two myself. I think you lose a whopping 5 hp backing off 3 or 4 degrees. Not enough to notice IMO. Depending on what size shot your running you could probably just run stock timing. Just make sure your not getting any knock retard.
Edit: If your just spraying a 125 shot on that T/A and those mods I would say your fine.
