GTO Gas tank hose routing
I am looking for the GTO gas tank fuel line and vent routing. Trying to do Smog legal swap and would like to use a GTO fuel pump grafted into my current tank along with evap vent line.
Just need someone who has experience in the GTO's fuel pump/gas tank and pressure regulator.
Is the regulator inside the pump like the F body or is it external.
is this it .
http://galleryplus.ebayimg.com/ws/we...5309_1_0_1.jpg
where does this go(to and from)? The hose in the tank.
http://i20.ebayimg.com/05/i/000/a7/b4/a31f_12_sb.JPG
this fitting on the bottom. hooks to?
http://i21.ebayimg.com/01/i/000/a7/b4/a931_3.JPG
where is the tank vent.
http://i20.ebayimg.com/03/i/000/a7/b4/a01f_3.JPG
is this it .
[QUOTE=Grve66;9520428]I am looking for the GTO gas tank fuel line and vent routing. Trying to do Smog legal swap and would like to use a GTO fuel pump grafted into my current tank along with evap vent line.
is this it .
http://galleryplus.ebayimg.com/ws/we...5309_1_0_1.jpg Pic no work but the reg. is in the pump assemble and can not be grafted to anything else.
http://i20.ebayimg.com/05/i/000/a7/b4/a31f_12_sb.JPG That is the feed off the pump
http://i21.ebayimg.com/01/i/000/a7/b4/a931_3.JPG Feed line to the fuel filter
[url]http://i20.ebayimg.com/03/i/000/a7/b4/a01f_3.JPG Tank vent is the big line off the top of the fuel pump assembly and goes up to the Filler neck tube.
Nate
is this it .
Nate
very cool, thank you Nate.
Now on the fuel pump there is these 2 connections. the long I know goes to the fuel tank out. but the short what looks to be cut.. Is that how how it is supposed to be.
http://www.auctiva.com/hostedimages/...s=0,0&format=0
Yeah that is where I am stumpped. . On the Lingenfelter pump install it shows it being disconnected first then the pump outlet. I am just wondering if it is part of the vent and where does it go.
also when you say the vent line comes out of the top of the fuel pump. and goes to the filler neck . Does it go to the evap canister and from the evap canister there is a line to the filler neck.
