a/c problems
a/c problems
i put some r-134a in my car the other day cause it was low, it blew cold air so i figured that it was all good, well i went to drive the car today turned on the ac and it blew warm air again. i got home checked it found it was low again so i put more in but it didnt seem that it want to fill in the ac. anyone know what the problem is?
see if you can find someone with a leak detector or you can check the lines an see if you find any deposits of oil built up, thats usually a good indicator of a leak, should have a yellowish or greenish tint to it.
