Will the SES light shut off by itself?
Old 06-09-2008, 09:58 PM
PAFbird's Avatar
Default Will the SES light shut off by itself?
Will the SES light shut off by itself if the problem causing it is fixed or do the codes have to be cleared out of the computer? I've decided to do some of the easy repairs myself and need to know what I should do about the SES light.
Just in case it matters, the car threw the 420 code for bad cats/O2 sensors/etc..
I'm in the process of changing out the spark plugs, possibly the O2 sensors and if that doesn't work...the cats.
Thanks!
Old 06-09-2008, 11:29 PM
lusting4ls1's Avatar
yeah, if you fix was causing it to be on, it will turn off.
Old 06-10-2008, 12:16 AM
atxz/28maro's Avatar
ACTION TAKEN WHEN THE DTC SETS
The PCM will illuminate the Malfunction Indicator Lamp (MIL) during the first trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame/Failure Records data.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM will turn the MIL OFF during the third consecutive trip in which the diagnostic has been run and passed.
The History DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using a scan tool.
https://ls1tech.com/forums/showpost....54&postcount=2
