New cam dyno numbers!
I just dynoed my Trans Am yesterday with the new cam.Its a Comp XE 230/230 with .572/.572 lift ona 110+4 lsa.The air was 87 deg with 66% humidity.With the stock LS1 intake,stock t-body,stock programming,Hooker L/Ts w-orp,Borla catback,160 deg t-stat the car made 372.9 hp at 5600rpms and 367.3 lb/ft tq at 4700rpms.Theres more in the car with tuning and the air fuel ratio averaged 13.0 all the way through the run.Ill post the dyno graph as soon as I figure out how to use my scanner.
Re: New cam dyno numbers!
I run my track times at Lebanon Valley.The heads/t-body/intake/pulley/tuning are totally stock.Driveability is way better than I thought it was gonna be.Idle hunts once in a while and it sometimes stalls with the a/c on but Ill fix that with some adjustments.
