E-cutout with side exit?
Old 06-10-2008, 03:34 PM
35thUCF's Avatar
Default E-cutout with side exit?
Has anyone combined a cutout in the usual spot before the over axle pipe with a pipe that exits before the tire? I am tired of the exhaust turning my parts black.
Old 06-10-2008, 04:57 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Havent seen a single,,but someone here did side exit duals...try a SEARCH maybe.
Old 06-10-2008, 04:59 PM
NHRAMAN's Avatar
Nothing comes up in search.
Old 06-10-2008, 05:42 PM
OEM_TA's Avatar
Are you using a turn down pipe?
I am using one that turns the exhaust opening straight to the ground.
Mine is is the same spot as yours, but I have no issues with exhaust sooting up parts.
I got it from the same folks who supplied the cutout.
Old 06-11-2008, 08:42 AM
35thUCF's Avatar
No turn down, I just want the sound, and the carbon to be shot out at the car beside me, not on the road. I guess I am just an @$$hole.
Old 06-11-2008, 05:38 PM
OEM_TA's Avatar
Ahha, ok I thought you were just concerned with the sooting up of the parts on the car.
In your case I would buy a collector and head to a muffler shop and have them bend you a pipe to fit.
On a side note, even with mine pointed at the ground, I have had no problems with folks to the right and left hearing the exhaust with the cutout open... in fact folks for about a block radius will stop what they are doing and look, along with mouthing obscenities and waving with one finger.
Old 06-11-2008, 05:51 PM
spy2520's Avatar
with a turn down you can angle it to shoot out the side. If it faces down you'll probably end up with alot of vibration in the car anyways.
