What else do I need>?
heres a list of what I have
I have a post of some of this list installed but this will be my project next week
let me know if you see that I'm missing something.
ok this is what I have so far I hope I'm not missing anything if you see something let me know
set - Pacesetter Long Tube Headers (coated w/egr/air)
set - Pacesetter Off road Y-pipe
3 - 3" exhaust clamps
2 - hanger bolts/nuts
6 - EGR/AIR bolts
12- header bolts w/washers
2 - header gaskets
2 - air gaskets
1 - EGR gasket
2 - o2 extensions
2 - o2 sims
8 - NGK v-series (tr55)
1 - set MSD wires
1 - Bosch oil filter
1 - fuel filter
6 - Qts Castrol GTX high mile 5w-30
1 - glowshift oil filter sensor adaptor
1 - glowshift oil temp gauge w/sensor
1- -glowshift trans temp w/sensor
1 - glowshift air/fuel ratio gauge
4 - jack stands
2 - jacks
2 - work lights
2 - cans PB penetrating oil
all my tools (esp 10mm and alot of extenders as well as patience)
1 - glowshift decal
2 - pacesetter decals
2 - Hooker decals
1 - set red bawls
if I should be forgetting something let me know I'm attacking this job next thursday
6 - EGR/AIR bolts
2 - header gaskets
2 - air gaskets
1 - EGR gasket
2 - o2 extensions
2 - o2 sims
1 - set MSD wires
1 - fuel filter
4 - jack stands
2 - jacks
2 - work lights
1 - glowshift decal
2 - Hooker decals
1 - set red bawls
Poly motor mounts.
Im glad I came across this thread because I will be doing the same thing within the next couple weeks. Ill be ordering the TSP Y instead of the Pacesetter Y though.
wasn't sure if I wanted to go with poly mounts my stock mounts are fine plus I don't plan on going nuts with this the only other thing I'll do to this car right now is a strut tower brace and sub frame connectors this is my DD and don't want the excess vibration.
