having trouble keeping filter hat on procharger after fmic and bringing rad forward
Old 06-11-2008, 09:03 PM
98turbls1's Avatar
Default having trouble keeping filter hat on procharger after fmic and bringing rad forward
it seems my itake hat doesn't want to stay on since i've put my fmic on and pushed my rad forward for room... has anyone else had this problem and if so what did you do to fix it???
Old 06-12-2008, 05:04 AM
EPP
EPP's Avatar
The mods should not affect the intake hat. If you have added a larger filter assembly to the inlet assembly, perhaps you need a brace/support added to handle the added weight. Also, if you are using a worm clamp on the inlet hat, try using a t bolt clamp instead. Most Napa stores carry t bolt clamps. Bob
