will mototron 60's fit.?
i am new to this efi.. have a 6.0 lq4 in 70 chevelle. turbo's are installed.. i am looking at the mototron 60's.. will they just drop right down in the old injectors . or will there be mods i have to do.? could there be an other injector that would work?. thanks for ya help.. still learning all this technology..
Are you running the truck intake or a car intake? If you have the truck intake, then you can use them, you just have to put 5/8 spacers on the fuel rail mounts and change the injector plugs to match the injectors as the truck injectors are different. I am running the Mototron 60's on my truck
Depending on how much power you want to make, you could alway just put the MARINE 8.1L injectors in the truck manifold, there are a direct replacement and 43lbs/hr. They are good for about 500 rwhp.
yea i just went with 44lbs they fit right in and still have same plug types.. . when i put some l92 heads and blower cam i will upgrade them.. will a car intake fit.. i think i heard problem clearing the water pump?..
