fuel usage seems odd
with the last couple of tanks of gas ive used. i can go around 125 miles on my first quarter tank then the last three quarters go within the next 75 miles it just seems odd. i rarely switch octane i run 88 and every once in awhile ill run a tank of 91 to clean it up alittle the car has just over 100k on it. just wondering if anyone else has the same fuel usage. thanks. o yeah and i seafoamed it on my last oil change
I think it all has to do with the way the gage and sending unit work. I've had several cars including the Dodge truck I have now that seem to be the same way. You also have to consider the fuel thats in your filler neck. The sending unit will read full even though your actually more than full when there's fuel in the filler neck. Your gage is not going to indicate any usage of fuel until the volume of fuel in the filler neck is used. Thats why it sees you are getting more millage with the first half of the tank.
