QA1 Front struts - will they make a huge difference
Heres the deal. I have a 94 z28. Basically I upgraded every suspension piece that there is except the front struts which are still stock. I was thinking about buying those QA1 Struts with the 300lb springs. Mostly a street/strip car. Will they make a huge difference in my launch. I'm running comp eng. 3 way drag shocks in the rear set at 50/50, no front sway bar, 15x3.5 rims up front and 325's in the rear. Will these struts allow my front end to pick up alittle?
LS1Tech Premium Sponsor
Hello, the QA1's will make a difference especially if you get the double adjustable ones. They allow you to adjust the rebound and compression seperately. If those are too expensive then the single adj will be a major improvement over what you have now. If you have any questions please give me a call. Our sales/tech dept is open MON-FRI 8:30AM-6:00PM EST. Here is a link to our site.
http://www.bmrfabrication.com/F-bodySuspension.htm
https://ls1tech.com/forums/lsx-parts-sale/940033-bmr-qa1-american-racing-patriot-kicker.html
I just bought these from BMR......Thought I'd save ya some money
