New Best - 6//2008
New Best - 6//2008
Went to Cordova for a track rental to make some passes before the St Louis Pinks All Out event to test some changes out. I completely removed the front sway bar, removed some other weight ~3575 and changed to bigger injectors.
We got a late start, just picked up a new hauler, 05 Dodge Dualie, then had to get the trailer and load the car. Unloaded and got the car mostly set up to run, had ~2psi more air than I wanted but I was tired of letting air out and wanted to make a pass. After a break for fluid on the track I got to make a pass, spun off the line and went a little left and had to bring it back but ended up running a new best for the Car / Combo. While I was looking at the data from the run it started to rain and we got rained out. At lest the only pass was a new best.
1.617 60'
7.571@91.74
11.835@117.17
1.617 60'
7.571@91.74
11.835@117.17
