PCV Question
PCV Question
I have searched and searched. I need a concrete answer as to what I need to do.
I have a 98 LS1. I swapped over to LS2 heads.
How should I route the PCV system?
If someone has a diagram, I would greatly appreciate them posting it.
Currently its set up like this: A tube coming off the intake, goes to the pcv valve, which is connected to the driver's side valve cover port. The passenger side valve cover port is connected to the hose coming off the t-body. Is that set up correct or okay? If its not correct, how should I route it? TIA.
