O F I C6 single turbo release!!!
Here is the official release of the C6 single front mount turbo kit. The kit includes some of the best products on the market today. I use only parts made in the USA on my kits.
The setup that I designed is for the T6 turbos from Forced Inductions. Any of there "S" series turbos will fit on this kit. The setup is a bolt on kit with no cutting of anything in the engine bay or moving of any accessories. The power that they are capable of making is based on your engine setup and drivetrain. You should have no proplem making some single digit passes with a built setup. Here are the standered parts that come with the kit. The only options are the turbos sense everything else is included with the standered kit.
Here are some pictures of the setup.....
The whole front of the C6 unbolts with 4 bolts and the a/c and radiator setup boolts on and lift right back up in to the car.
The turbo support system is configured by 2 gas spring shocks with 50 pound force each. They are attached to the turbo flange then to the car front. The shocks move with engine movement with no proplem.
The will come with S76mm turbo and you can add on any "s" series turbo to the kit. It will fit up to the S91. I will have the website updated by weeks end. The price of the kit are as follows
T6 C6 Single Turbo Kit $8999.95 retail
Intro Special Price for first 5 $7999.95
- 1 3/4 Headers
- 3/8 Thick header flanges
- Weld-on collectors
- 2 1/2 V-bands on headers/x-over
- T6 flange
- 2 1/2 Crossover
- 3 1/2 Downpipe
- 2 1/2 Y-pipe to connect to stock exhaust
- 2- 3 1/2 Band clamps
- 2- 2 1/2 Band clamps
- 1- 3" band clamps
- Tial 46mm wastegate
- Ceramic coating inside and out
- Turbo blanket
- Turbo support setup
- Heat shields
- Fuse box brackets
- 02 extension
- 3 1/2" Aluminum radiator with stock snap ring connections
- Coolant tank
- Radiator hoses
- 3" silicone 90's
- 3" to 4" reducer silicone
- 16" spal fan
- Heater hose sleeve
- Oil lines feed -4
- Oil line return -10
- A/C line
- 3" dual intercoolers
- 50mm Tial bov
- s/s bov flange
- 3" t-clamps
- 4" t-clamps
- 2 1/2 t-clamps
- All bolts and nuts included
- All brackets included
Whats the power looking like? My buddies Bone Stock LS2 with the APS kit does 738RWHP. How does it compare? The install really doesnt look that bad as a "do it yourselftproject"
