need to double check
i had a brake line i bought with a bubble flare at one end i bent it and not i had to cut it off
will my line im maken going to the master cylinder be fine if its just double flared?
haven't done brake lines in a LONG time
also sawing too close to the stock mc fitting i took some metal away from the tip of the fitting idk if that matters i can get a pic
