6.0 LS6 cam 15PSI Comp 918's OK
Lift is one thing, but not what you match a spring to, unless you're beyond the capability of a lesser spring. You want to match your springs to the cam's ramp rate, but I noticed your sig. You're going with a turbo. Will a 918 be able to keep a valve closed without bouncing when you're max boost and WoT? FI applications usually want to run more spring (seat pressure).
Yes, they are fine, just make sure you run hem at 1.8 height and titanium retainers a plus. I run them on my Supercharged C6, 10 psi with .568 lifts XE lobes, no issues for 1 year
