Which gear ratio (3.89 or 4.10)
Old 06-27-2008, 02:12 PM
LM97Z's Avatar
Default Which gear ratio (3.89 or 4.10)
For an M6 running 26" tires & nitrous.
Old 06-28-2008, 06:58 AM
EPP
EPP's Avatar
It is going to depend on how high you are willing to rev your engine through the traps, and how much horsepower you are making. With a short 26" tire and nitrous, I'd say 3.89's. Bob
Old 06-28-2008, 07:50 AM
00 Freak's Avatar
u also gotta think about what are your future plans. if plan on swapping your cam some of them recommend to have a set of 4.10 gears.
Old 06-28-2008, 10:06 AM
proelky's Avatar
I would run a 4.10/11 gear and a 28" tire for the track. I run a 26" on the streets.
Old 06-28-2008, 10:15 AM
LM97Z's Avatar
I may never change the cam, heck @ the rate i'm going trying to get the rearend set-up, i may never get nitrous lol, i'm sure theres not a whole lot of difference from a 3.90 to 4.10, i just want to be able to stay in 4th. through the 1/4 on a stock cam (on motor).
Old 06-28-2008, 10:35 AM
98catfish's Avatar
If its a stock rear 4.10s usually have a lot of gear noise I would go 3.90s.
Best option = save your money till you can get a 12 bolt or 9". I just sold one for 1600.00
I would never waste my money on a stock rear again. If you interested I have a almost new eaton posi and 28 spline axles and girdle for sale.
Doug
Old 06-28-2008, 10:49 AM
sstony's Avatar
i'm running 4.10 cuz 3.90 were not available for the S60. i'm running a 26" tire and my shift light is on at the end of the 1320 in 4th gear but i'm not bouncing off the limiter. so if you are on the spray, i'd think either 3.89 or go with a taller tire if you do the 4.10, something like a 28
Originally Posted by 98catfish
If its a stock rear ...I would never waste my money on a stock rear again.....
i totally agree after rebuilding/replacing my 10 bolt 4x and $1500 later. his sig says mosier 9" so he's safe.
