Cam only swap C5 Auto.
Funny I forgot to talk about this here..
My father has a 2000 C5 convertible and I currently work at a custom cam shop and am able the get cams ground pretty cheap.
His car has about 35,000 on it and he commonly drives it cross country. Thought I would run this set-up by you guys, to see if this type of set-up would effect mileage at all or have other issues?
Will be having it tuned after install will this be able to be driven 200-300 miles from his place to my tuners?
Cam is a 224/230 .595/.595 113 LSA
Plan also on doing PSI 1511 springs and Trend push rods with the cam install.
May also do a LS2 or true roller timing set.
I'm hoping it will leave a little room for growing, maybe a stall, headers ,243 heads and LS6 intake down the road.
Thanks in advance,
Chad
Thanks in advance,
Chad
