Expert thoughts on this cam. Cam card attached
I've searched and have yet to find a post with the cam card to the Lunati Voodoo 232/238 cam and thoughts on it. I'd like to know what the cam guys think of this cam and it's design. It's got to be better than the old 231/237 TSP Lunati grind I'm running now. But. How much better? This is in a stock bottom end LS1 with mods in sig. Please take the time to give me your thoughts.
Secondly, I really do not want to pull the heads off again so is there any way to figure if PTV will be okay with this cam without removing the heads? They are AS Stage II 5.3 heads supposedly unmilled.
[IMG][/IMG]
Thanks in advance
Shawn
[IMG][/IMG]
Thanks in advance
Shawn
I don't know the LSA/ICL of your current cam, but I doubt you could tell the difference of the two cams. They are only one degree of duration off, and the variance in grinding could make them identical. So unless the lobes are way different, I don't think its worth it.
