need to know what size cam????
Old 08-19-2003, 08:02 AM
johnster's Avatar
Default need to know what size cam????
Thinking of putting a cam in my car,but don't know what size to going with.What do you guys think with my mods.I drive the car almost every day. thanks
Old 08-19-2003, 08:03 AM
boomcase's Avatar
Default Re: need to know what size cam????
Do you want to tune it or leave stock tune.
Old 08-19-2003, 08:31 AM
johnster's Avatar
Could I tune it with the maft? Or will i need edit or something else.How much HP will I can from a cam that you don;t have to tune?
Old 08-19-2003, 08:55 AM
MyLS1Hauls's Avatar
If you do a search on here or the other site, you'll come up with enough cam data to keep you occupied for a week straight.
Old 08-19-2003, 11:18 AM
LawmanSS's Avatar
Yeah...I think I've read all that cam data...it has kept me occupied since mid June and I still haven't picked a cam!
Old 08-19-2003, 11:37 AM
Tin Indian's Avatar
You have an automatic...
Slap a TR220 in there. Even with that, I needed PCM work done so the car would not stall while idling in Drive. Drilling the throttle plate hole helped, but until Thunder tweeked the PCM, it did not idle in gear good at all. The trick to make these A4 cammed cars idle good is to increase idle timing. If this is your daily driver, I can't see that you would need any more cam than the 220.
