Nozzle to plate switch?
I have a TNT wet kit with the nozzles before the tb (90mm). Can I swap in a plate, like a Harris Speed works 90mm perimeter plate?
This is pretty much what I have (not my pic)
This is what I want
Sorry if this is a stupid question.
This is what I want
whoops, didnt realize which setup that was, i just saw two nozzles and assumed it had 4 solenoids. All you would do is remove the T that splits lines from the solenoid and run the line directly into the solenoid to the plate. Traditionally our kit comes with a longer nitrous lines then fuel line to combat leans spikes which you would have on any plate kit with equal lines. I would setup everything and get it on the dyno, if you see an excessive spike we can make you up a longer nitrous line.
I had to get a three foot fuel line because the fuel port is on the back of the passenger fuel rail on my rails. I have a professional products fuel rail. I am planing on going with a dedicated fuel cell in the stock battery location. Nitrous line is from the kit.
If you run a 180 off the back of the rail you could probably shorten that hose length to 18 to 24 inches at most with the plate kit. One way or the other the plate will work in your situation.
