trying to install rear sway bar
Old 06-30-2008, 07:55 PM
89Formulaws6's Avatar
Default trying to install rear sway bar
ok so i got my 9in installed grinded away some of the part thats needed for the sway bar to fit (hits the back side of where the torque arm mounts)
grinded it a little now i got it to where the sway bar goes on but the bushings are angled towards the rear of the car
does the sway bar need to be directly under the rear? also do the clamps have to be faceing straight down?didnt wanna grind too much if this will be enough
heres some pics tried to get the best as possible
Old 06-30-2008, 09:15 PM
Manic Mechanic's Avatar
That should be fine. The effectiveness is best centered but that isn't enough to worry about.
Vernon
Old 07-02-2008, 09:47 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Looks fine.You want to make sure that none of the parts contact each other when the car suspension travels.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Quick Reply: trying to install rear sway bar
