horn
horn
so my horn died, i got a air horn kit from like autozone but i only have 2 horns the air pump and tubeing
not sure on how to hook it upbottom of the air pump is a - and + not sure if i can just hook up a positive and ground and be fine thouht i'd check here first
Ungrounded Moderator
Just connect it to the original horn wiring - dark green for positive and black for negative. You might notice that the air horns won't sound when you arm/disarm the alarm because the compressor takes a second to spool up and provide pressure - the short beeps of the alarm aren't long enough.
